[GRASS-dev] [GRASS GIS] #2900: The user environment settings in .grass7/bashrc are skipped
trac at osgeo.org
Mon Sep 3 14:33:48 PDT 2018
Reporter: micha | Owner: grass-dev@…
Type: task | Status: closed
Priority: normal | Milestone: 7.2.4
Component: Startup | Version: 7.0.3
Resolution: fixed | Keywords: bashrc grass.py env
CPU: Unspecified | Platform: Linux
Changes (by wenzeslaus):
* status: new => closed
* keywords: bashrc => bashrc grass.py env
* resolution: => fixed
* milestone: 7.0.7 => 7.2.4
Comment:
Both `~/.grass.bashrc` and `~/.grass7/bashrc` are used `bash_startup()`
function in `grass.py in 7.2 at least since r65585. `~/.grass7/bashrc` is
used in the `load_env()` function and in the documentation. Changing
milestone to 7.2.x and closing as fixed.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2900#comment:4>
