[GRASS-dev] [GRASS GIS] #3170: GRASS_BATCH_JOB does not tolerate path with spaces
trac at osgeo.org
Mon Sep 3 15:32:30 PDT 2018
Reporter: marisn | Owner: wenzeslaus
Type: defect | Status: new
Priority: normal | Milestone: 7.6.0
Component: Startup | Version: svn-trunk
Resolution: | Keywords: grass.py init spaces exec
CPU: | GRASS_BATCH_JOB Popen shell=True
Unspecified | Platform: Unspecified
Changes (by wenzeslaus):
* owner: grass-dev@… => wenzeslaus
* keywords: grass.py, init => grass.py init spaces exec GRASS_BATCH_JOB
Popen shell=True
* milestone: 7.2.4 => 7.6.0
Comment:
For 7.2 and 7.4 (and maybe 7.6) the workarounds are:
1. Don't use `GRASS_BATCH_JOB`, use more powerful `--exec` instead.
2. Don't use spaces in the path. (And please let us know why do you prefer
`GRASS_BATCH_JOB` rather over `--exec`.)
The spaces-in-path support can be implemented like this:
#!diff
Index: lib/init/grass.py
--- lib/init/grass.py (revision 73229)
+++ lib/init/grass.py (working copy)
@@ -1511,9 +1511,17 @@
batch_job_string = batch_job
if not isinstance(batch_job, string_types):
batch_job_string = ' '.join(batch_job)
message(_("Executing <%s> ...") % batch_job_string)
if isinstance(batch_job, string_types):
+ def quote(string):
+ if '"' in string:
+ return "'%s'" % batch_job
+ else:
+ return '"%s"' % batch_job
+ batch_job = quote(batch_job)
proc = Popen(batch_job, shell=True)
else:
try:
Here `shell=True` (which is splitting the command using spaces) is used
because it was used with `GRASS_BATCH_JOB` in the past. `--exec` is not
using `shell=True` and allows spaces. Note that for 8.0 there might be
changes to `GRASS_BATCH_JOB` in order to make it more aligned with
`--exec` (see wiki:Grass8Planning).
''Milestone is 7.6 or 7.8.''
Ticket URL: <https://trac.osgeo.org/grass/ticket/3170#comment:6>
