[GRASS-dev] [GRASS GIS] #3635: Suspicious use and cleanup of the mapset tempoary directory
trac at osgeo.org
Mon Sep 3 19:23:36 PDT 2018
Reporter: wenzeslaus | Owner: wenzeslaus
Type: defect | Status: new
Priority: normal | Milestone: 7.6.0
Component: Startup | Version: svn-trunk
Resolution: | Keywords: init grass.py clean_temp .tmp temp
CPU: | g.mapset wxGUI rendering
Unspecified | Platform: All
Changes (by wenzeslaus):
* owner: grass-dev@… => wenzeslaus
Comment:
The commit message for r54467 does not specify why the change - addition
of `os.path.join(location, ".tmp")` - was needed and what is its relation
to `clean_temp`. (Note that "location" means full path to mapset; same
below.)
Similar line is `cleanup_dir(os.path.join(location, ".tmp"))` with comment
"remove GUI session files from .tmp" which is called on MS Windows for GUI
startup suggests some cleaning after GUI. However, it comes from the
original translation of the startup script to Python (r37863). It
originated from r21048 which was working around some bug related to
!Tcl/Tk GUI.
If GUI works as expected after #3637, the GUI files should disappear from
the mapset tmp dir because all will be in the system tmp dir, then the
line from r37863 won't be needed if its comment refers to rendered files.
As for r54467, I don't see why `clean_temp` is not enough. So, unless I
find something, e.g. that `clean_temp` is broken or somebody suggests why
it is there, I'm going to remove this clean up and let `grass.py` rely on
`clean_temp`.
''Preferred milestone: 7.8 (not in Trac yet)''
Ticket URL: <https://trac.osgeo.org/grass/ticket/3635#comment:1>
