[GRASS-dev] [GRASS GIS] #3637: Use the system temporary directory for all GUI rendering files
trac at osgeo.org
Sat Sep 15 13:49:20 PDT 2018
Reporter: wenzeslaus | Owner: grass-dev@…
Type: defect | Status: closed
Priority: minor | Milestone: 8.0.0
Component: wxGUI | Version: svn-trunk
Resolution: fixed | Keywords: rendering PPM g.pnmcomp tempfile
CPU: | NamedTemporaryFile
Unspecified | Platform: Unspecified
Comment (by wenzeslaus):
I tested the rendering with rasters, vectors and vector legend and it
works including checking and unchecking. A debug output (WX_DEBUG=5,
edited) after pressing ''Render map'' button is below showing only files
in the session temporary directory which is in the system temporary
directory (here /tmp).
GUI D3/5: Layer.Render(): type=overlay, name=vectleg,
file=/tmp/grass7-$USER-11834/tmp0v6vpY.png
GUI D1/5: RenderLayerMgr.Render(d.legend.vect at=20.0,80.0):
force=0 img=/tmp/grass7-$USER-11834/tmp0v6vpY.png
GUI D3/5: Layer.Render(): type=raster, name=aspect at PERMANENT,
file=/tmp/grass7-$USER-11834/tmpmpjTAK.ppm
GUI D1/5: RenderLayerMgr.Render(d.rast map=aspect at PERMANENT):
force=0 img=/tmp/grass7-$USER-11834/tmpmpjTAK.ppm
GUI D3/5: Layer.Render(): type=vector, name=bridges at PERMANENT,
file=/tmp/grass7-$USER-11834/tmpY1Ns6j.ppm
GUI D1/5: RenderLayerMgr.Render(d.vect map=bridges at PERMANENT width=1):
force=0 img=/tmp/grass7-$USER-11834/tmpY1Ns6j.ppm
GUI D1/5: gcmd.RunCommand(): g.pnmcomp --o opacity=1.0,1.0 width=825
mask=/tmp/grass7-$USER-11834/tmpmpjTAK.pgm,/tmp/grass7-$USER-11834/tmpY1Ns6j.pgm
height=572 bgcolor=255:255:255
input=/tmp/grass7-$USER-11834/tmpmpjTAK.ppm,/tmp/grass7-$USER-11834/tmpY1Ns6j.ppm
output=/tmp/grass7-$USER-11834/tmpSwtqYx.ppm
Ticket URL: <https://trac.osgeo.org/grass/ticket/3637#comment:2>
