[GRASS-dev] [GRASS GIS] #3637: Use the system temporary directory for all GUI rendering files
GRASS GIS trac at osgeo.org
Sat Sep 15 13:37:13 PDT 2018
  Reporter:  wenzeslaus  |      Owner:  grass-dev@…
      Type:  defect      |     Status:  closed
  Priority:  minor       |  Milestone:  8.0.0
 Component:  wxGUI       |    Version:  svn-trunk
Resolution:  fixed       |   Keywords:  rendering PPM g.pnmcomp tempfile
       CPU:              |  NamedTemporaryFile
  Unspecified            |   Platform:  Unspecified
Changes (by wenzeslaus):
 * status:  assigned => closed
 * resolution:   => fixed
Comment:
 In [changeset:"73334" 73334]:
 #!CommitTicketReference repository="" revision="73334"
 wxGUI/core: replace grass.script.tempfile by tempfile.NamedTemporaryFile
 (fixes #3637)
 Switches from mapset temporary directory to system temporary
 directory which was previously set up for the session for
 all GUI rendering files.
 This also refactors and unifies handling of the temporary files related
 to rendering, although on error and when removing/deleting the layers
 removing of the files happens in the same way as before.
 All files are now using NamedTemporaryFile instead of some using
 g.tempfile and some NamedTemporaryFile. This means that when mapset
 is switched, files are present in the (correct) session directory,
 not incorrect mapset directory and then not deleted later.
 (Deleting these files could cause rendering errors, while not deleting
 them would lead to accumulating of files in mapset temporary directory).
 See also:
  * r28605 which adds glob for one delete when core.utils.GetTempfile(),
    i.e., g.tempfile was still used (the glob part is still there)
  * r56444 which adds mkstemp() for some of the files
  * r60947 attempt to fix cleaning of deleting temporary files (#560)
    which changes mkstemp to NamedTemporaryFile (still used now)
  * r69085 which checked legend row file (legrow) name of last character
    being digit (isdigit()) which was true for files from g.tempfile
    but does not seem to have a reason (removed now)
  * #3635 which investigates a suspicious cleanups of mapset temporary
    directory which at this point seemed to be cleaning rendering files
    from GUI (r37863, r21048)
Ticket URL: <https://trac.osgeo.org/grass/ticket/3637#comment:1>
