[GRASS-dev] [GRASS-user] experimental Python 3 support in trunk
Markus Neteler
neteler at osgeo.org
Mon Sep 3 23:00:23 PDT 2018
On Tue, Sep 4, 2018 at 12:39 AM Anna Petrášová <kratochanna at gmail.com> wrote:
> are you sure you did make distclean?
You are right, solved with that.
Here a few more issues: At wxGUI startup:
### in the terminal:
07:37:09: Debug: Adding duplicate image handler for 'Windows bitmap file'
--> perhaps from an underlying lib?
### in the wxGUI console:
> Menu > System info
3D view mode not available
Reason: name 'WindowsError' is not defined
Vector digitizer not available
Note that the wxGUI's vector digitizer is disabled in this
installation. Please keep an eye out for updated versions of
GRASS. In the meantime you can use "v.edit" for non-
interactive editing from the Develop vector map menu.
/home/mneteler/software/grass77/dist.x86_64-pc-linux-
gnu/gui/wxpython/mapwin/buffered.py:406:
wxPyDeprecationWarning: Call to deprecated item. Use
DrawLine instead.
coords[i][1]))
System Info
File "/home/mneteler/software/grass77/dist.x86_64-pc-
linux-gnu/gui/wxpython/lmgr/frame.py", line 1259, in
OnSystemInfo
_("Platform"), platform.platform().decode('utf8',
'replace'), osgeo4w),
AttributeError
'str' object has no attribute 'decode'
display raster > select map > OK button
DrawLine instead.
coords[i][1]))
DrawLine instead.
coords[i][1]))
# seen in the terminal:
from grass.pygrass.vector import VectorTopo
File "/home/mneteler/software/grass77/dist.x86_64-pc-linux-gnu/etc/python/grass/pygrass/vector/__init__.py",
line 7, in <module>
import grass.lib.vector as libvect
File "/home/mneteler/software/grass77/dist.x86_64-pc-linux-gnu/etc/python/grass/lib/vector.py",
line 5863
PORT_LONG_MAX = 2147483647L
SyntaxError: invalid syntax
Markus
