[GRASS-dev] [GRASS-user] experimental Python 3 support in trunk
Anna Petrášová
kratochanna at gmail.com
Tue Sep 4 06:21:45 PDT 2018
On Tue, Sep 4, 2018 at 2:00 AM Markus Neteler <neteler at osgeo.org> wrote:
> On Tue, Sep 4, 2018 at 12:39 AM Anna Petrášová <kratochanna at gmail.com>
> wrote:
> > are you sure you did make distclean?
> You are right, solved with that.
> Here a few more issues: At wxGUI startup:
> ### in the terminal:
> 07:37:09: Debug: Adding duplicate image handler for 'Windows bitmap file'
not sure about this, but seems minor right now
> --> perhaps from an underlying lib?
> ### in the wxGUI console:
> > Menu > System info
> 3D view mode not available
> Reason: name 'WindowsError' is not defined
> Vector digitizer not available
> Note that the wxGUI's vector digitizer is disabled in this
> installation. Please keep an eye out for updated versions of
> GRASS. In the meantime you can use "v.edit" for non-
> interactive editing from the Develop vector map menu.
> /home/mneteler/software/grass77/dist.x86_64-pc-linux-
> gnu/gui/wxpython/mapwin/buffered.py:406:
generally, that's the problem with ctypes which is not fixed yet, I can
look what that 'WindowsError' means specifically
> wxPyDeprecationWarning: Call to deprecated item. Use
> DrawLine instead.
> coords[i][1]))
minor, should be easy to get rid of it
> System Info
> Traceback (most recent call last):
> File "/home/mneteler/software/grass77/dist.x86_64-pc-
> linux-gnu/gui/wxpython/lmgr/frame.py", line 1259, in
> OnSystemInfo
> _("Platform"), platform.platform().decode('utf8',
> 'replace'), osgeo4w),
> AttributeError
> 'str' object has no attribute 'decode'
I will look at that, should be easy
> display raster > select map > OK button
> DrawLine instead.
> coords[i][1]))
> DrawLine instead.
> coords[i][1]))
> # seen in the terminal:
> from grass.pygrass.vector import VectorTopo
> File
> "/home/mneteler/software/grass77/dist.x86_64-pc-linux-gnu/etc/python/grass/pygrass/vector/__init__.py",
> line 7, in <module>
> import grass.lib.vector as libvect
> File
> "/home/mneteler/software/grass77/dist.x86_64-pc-linux-gnu/etc/python/grass/lib/vector.py",
> line 5863
> PORT_LONG_MAX = 2147483647L
> SyntaxError: invalid syntax
as I said, that's the ctypes problem, weird is I don't get this specific
problem, when I compile it, I get PORT_LONG_MAX = 2147483647 (without the
L)
> Markus
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20180904/4efa817d/attachment.html>
