[GRASS-dev] [GRASS GIS] #3638: v.distance linear matrix remove duplicate cat column & table associated without having map of distance lines
GRASS GIS trac at osgeo.org
Wed Sep 5 06:02:16 PDT 2018
  Reporter:  Maellevd     |      Owner:  grass-dev@…
      Type:  defect       |     Status:  reopened
  Priority:  normal       |  Milestone:
 Component:  Vector       |    Version:  7.4.0
Resolution:               |   Keywords:  v.distance
       CPU:  Unspecified  |   Platform:  Linux
Changes (by sbl):
 * status:  closed => reopened
 * resolution:  worksforme =>
 * type:  enhancement => defect
Comment:
 Sorry, I was a bit quick and see that
 v.distance -p -a from=hospitals to= hospitals upload=cat,dist
 indeed produce duplicate columns
 Also,
 ERROR: Bug: attempt to update map which is not in current mapset
 should not happen.
 In addition, the resulting map also lacks an attribute table (which it
 should have). In more detail, the attribute table is produced, but not
 connected to the vector map...
 Writing table-formated output from GRASS directy to the database is a
 different issue, and might be useful in more modules...
Ticket URL: <https://trac.osgeo.org/grass/ticket/3638#comment:2>
