[GRASS-dev] [GRASS GIS] #3150: Simple r.out.png region enhancement
trac at osgeo.org
Fri Sep 14 14:20:00 PDT 2018
Reporter: huhabla | Owner: grass-dev@…
Type: enhancement | Status: new
Priority: trivial | Milestone: 7.4.2
Component: Raster | Version: svn-trunk
Resolution: | Keywords: r.out.png region
CPU: Unspecified | Platform: Unspecified
Changes (by wenzeslaus):
* keywords: r.out.png => r.out.png region
Comment:
Replying to [ticket:3150 huhabla]:
> I would like to post a patch that enables direct region settings in
r.out.png.
I agree that this would come handy time to time. For example, G7:r.mapcalc
(>=7.4) has region option to customize the region based on the inputs.
General modifications of region, such as the one you suggest, would apply
to many modules.
I think this would be better addressed generally as we discussed in
[https://lists.osgeo.org/pipermail/grass-dev/2016-September/082412.html
Adding an expert mode to the parser] and
[https://lists.osgeo.org/pipermail/grass-dev/2016-November/082927.html
Passing computational region to individual commands].
I suggest to close this as won't fix and open another ticket suggesting
change on the library and parser level or on the level of grass.py
covering the --exec case.
> This patch is only useful if the current region should not be changed or
can not be changed due to access restrictions of the mapset.
I was also in this situation and really for outputs and rendering, even
many GUI operations, there is no need to have any write access or
ownership (see also #2511). The current solution for this particular use
case and r.out.png is the GRASS_REGION environmental variable.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3150#comment:8>
