[GRASS-dev] [GRASS GIS] #3635: Suspicious use and cleanup of the mapset tempoary directory
trac at osgeo.org
Sat Sep 15 19:08:01 PDT 2018
Reporter: wenzeslaus | Owner: wenzeslaus
Type: defect | Status: new
Priority: normal | Milestone: 7.8.0
Component: Startup | Version: svn-trunk
Resolution: | Keywords: init grass.py clean_temp .tmp temp
CPU: | g.mapset wxGUI rendering
Unspecified | Platform: All
Comment (by wenzeslaus):
In [changeset:"73336" 73336]:
#!CommitTicketReference repository="" revision="73336"
init: do not remove wrong mapset .tmp, rely on clean_temp (see #3635)
The previous behavior was deleting whole mapset temporary directory
of a mapset set at the startup. When started in mapset A, switched to B,
exited, whole .tmp of A was removed, B was cleaned by clean_temp.
Now cleaning of A is done during switching (as before) but it is not
touched again, so no running processed in a (new) session in A are
in denger of loosing temporary files. The mapset active at exit is
cleaning using clean_temp as before, but only by that.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3635#comment:3>
