[GRASS-dev] [GRASS GIS] #3635: Suspicious use and cleanup of the mapset tempoary directory
trac at osgeo.org
Sat Sep 15 19:22:16 PDT 2018
Reporter: wenzeslaus | Owner: wenzeslaus
Type: defect | Status: new
Priority: normal | Milestone: 7.8.0
Component: Startup | Version: svn-trunk
Resolution: | Keywords: init grass.py clean_temp .tmp temp
CPU: | g.mapset wxGUI rendering
Unspecified | Platform: All
Comment (by wenzeslaus):
In [changeset:"73337" 73337]:
#!CommitTicketReference repository="" revision="73337"
init: remove basically dead code to clean mapset .tmp in default startup
(see #3635)
The default (fallback) startup contained code which was probably from the
original Python rewrite (r37863) and maybe originated from workaround in
r21048.
The clean_temp tool is called and takes care of cleaning, so this should
not
be neccessary, not even for GUI (mentioned in the comment). GUI is not
using
mapset temporary directory since r73334 (#3637).
Ticket URL: <https://trac.osgeo.org/grass/ticket/3635#comment:4>
