[GRASS-dev] [GRASS GIS] #3593: Error in v.stream.order add-on, segmentation fault
trac at osgeo.org
Sun Sep 16 09:35:18 PDT 2018
Reporter: jradinger | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone:
Component: Addons | Version: svn-releasebranch74
Resolution: | Keywords:
CPU: Unspecified | Platform: Unspecified
Comment (by mmetz):
Replying to [comment:4 neteler]:
> Replying to [comment:3 jradinger]:
> > How can I find out that step/line? Do I need to run the script
manually or can that be obtained by a specific debug level?
> The easiest way is to use pdb, see
https://grasswiki.osgeo.org/wiki/GRASS_Debugging#Python_debugging_with_pdb
You can also try valgrind:
CMD="v.stream.order input=streams points=streams_outlets
output=streams_order threshold=25 order=strahler,shreve --o"
valgrind --tool=memcheck --trace-children=yes --track-origins=yes --log-
file=val.out.%p $CMD
This will create a number of val.out.* files which you could zip/tar.gz
and attach to this ticket. No segfault and nothing suspicious in the
valgrind output on my system.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3593#comment:5>
