[GRASS-dev] [GRASS GIS] #3593: Error in v.stream.order add-on, segmentation fault
GRASS GIS trac at osgeo.org
Sun Sep 16 10:58:47 PDT 2018
  Reporter:  jradinger    |      Owner:  grass-dev@…
      Type:  defect       |     Status:  new
  Priority:  normal       |  Milestone:
 Component:  Addons       |    Version:  svn-releasebranch74
Resolution:               |   Keywords:
       CPU:  Unspecified  |   Platform:  Unspecified
Comment (by jradinger):
 I've not yet checked with `valgrind` or `pdb`, but I might have identified
 the line that might cause the problem (L390,
 https://trac.osgeo.org/grass/browser/grass-
 addons/grass7/vector/v.stream.order/v.stream.order.py#L390): This is the
 command `v.open(mode="r")`, where `v=VectorTopo('streams',
 'test_stream_order')`.
 I am not sure if this is a valid way to test but I ran the `v.open()`
 command manually within python (within a GRASS session):
 from grass.script import core as grass
 from grass.pygrass.vector import VectorTopo
 v = VectorTopo('streams','PERMANENT')
 v.open(mode="r")
 v.close()
 This causes (not sure if this is a valid approach/related):
   File "<stdin>", line 1, in <module>
   File
 "/Applications/GRASS-7.4.1.app/Contents/Resources/etc/python/grass/pygrass/vector/__init__.py",
 line 638, in close
     super(VectorTopo, self).close(build=build)
   File
 "/Applications/GRASS-7.4.1.app/Contents/Resources/etc/python/grass/pygrass/vector/abstract.py",
 line 402, in close
     if self.is_open():
   File
 line 283, in is_open
     return is_open(self.c_mapinfo)
   File
 line 21, in is_open
     return (c_mapinfo.contents.open != 0 and
 AttributeError: 'struct_Map_info' object has no attribute 'open'
Ticket URL: <https://trac.osgeo.org/grass/ticket/3593#comment:6>
