[GRASS-dev] [GRASS GIS] #3593: Error in v.stream.order add-on, segmentation fault
    trac at osgeo.org
    Sun Sep 16 12:28:40 PDT 2018
  Reporter:  jradinger    |      Owner:  grass-dev@…
      Type:  defect       |     Status:  new
  Priority:  normal       |  Milestone:
 Component:  Addons       |    Version:  svn-releasebranch74
Resolution:               |   Keywords:
       CPU:  Unspecified  |   Platform:  Unspecified
Comment (by mmetz):
 Replying to [comment:6 jradinger]:
 > I've not yet checked with `valgrind` or `pdb`, but I might have
 identified the line that might cause the problem (L390,
 https://trac.osgeo.org/grass/browser/grass-
 addons/grass7/vector/v.stream.order/v.stream.order.py#L390): This is the
 command `v.open(mode="r")`, where `v=VectorTopo('streams',
 'test_stream_order')`.
 > I am not sure if this is a valid way to test but I ran the `v.open()`
 command manually within python (within a GRASS session):
 > from grass.script import core as grass
 > from grass.pygrass.vector import VectorTopo
 > v = VectorTopo('streams','PERMANENT')
 > v.open(mode="r")
 > v.close()
 > This causes (not sure if this is a valid approach/related):
 > Traceback (most recent call last):
 >   File "<stdin>", line 1, in <module>
 >   File
 "/Applications/GRASS-7.4.1.app/Contents/Resources/etc/python/grass/pygrass/vector/__init__.py",
 line 638, in close
 >     super(VectorTopo, self).close(build=build)
 >   File
 "/Applications/GRASS-7.4.1.app/Contents/Resources/etc/python/grass/pygrass/vector/abstract.py",
 line 402, in close
 >     if self.is_open():
 >   File
 line 283, in is_open
 >     return is_open(self.c_mapinfo)
 >   File
 line 21, in is_open
 >     return (c_mapinfo.contents.open != 0 and
 > AttributeError: 'struct_Map_info' object has no attribute 'open'
 This does not make sense because the struct Map_info does have an
 attribute open:
 https://trac.osgeo.org/grass/browser/grass/trunk/include/vect/dig_structs.h#L1296
 However, I found a problem in pygrass:
 https://trac.osgeo.org/grass/browser/grass/trunk/lib/python/pygrass/vector/abstract.py#L77
 self.c_mapinfo must be a struct, not a pointer to a struct. This can cause
 a segfault because it seems that the memory for self.c_mapinfo has not
 been allocated.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3593#comment:7>
