[GRASS-dev] [GRASS GIS] #3575: Associate database/location/mapset with workspace file
GRASS GIS trac at osgeo.org
Sun Sep 16 12:21:48 PDT 2018
  Reporter:  wenzeslaus  |      Owner:  wenzeslaus
      Type:              |     Status:  closed
  enhancement            |
  Priority:  normal      |  Milestone:  8.0.0
 Component:  Startup     |    Version:  unspecified
Resolution:  fixed       |   Keywords:  workspace, location, wxGUI,
       CPU:              |  startup, save, load
  Unspecified            |   Platform:  All
Changes (by wenzeslaus):
 * status:  new => closed
 * resolution:   => fixed
Comment:
 In [changeset:"73348" 73348]:
 #!CommitTicketReference repository="" revision="73348"
 wxGUI: save database, location and mapset to workspace and switch it when
 opening it (closes #3575)
 It is no longer possible to just open workspace in a different mapset
 than the one where it was saved. However, when session element is not
 present (deleted or older gxw file) no mapset switching is performed.
 Older versions of GRASS GIS simply ignore the session element.
 An error message is given when mapset does not exist and options to
 proceed or not are given with some details (can be improved by
 diagnostics from grass.py if moved to library).
Ticket URL: <https://trac.osgeo.org/grass/ticket/3575#comment:3>
