[GRASS-dev] [GRASS GIS] #2681: Remove legacy meaning of LOCATION variable
GRASS GIS trac at osgeo.org
Sun Sep 16 18:15:38 PDT 2018
  Reporter:  wenzeslaus  |      Owner:  grass-dev@…
      Type:  task        |     Status:  new
  Priority:  blocker     |  Milestone:  8.0.0
 Component:  Startup     |    Version:  svn-trunk
Resolution:              |   Keywords:  init, grass.py, interface, CLI,
       CPU:              |  environment variables
  Unspecified            |   Platform:  All
Comment (by wenzeslaus):
 In [changeset:"73352" 73352]:
 #!CommitTicketReference repository="" revision="73352"
 init: use MAPSET_PATH instead of LOCATION for full path to current mapset
 variable (see #2681)
 Changes the (local) shell variable used to refer to full path to the
 current mapset from LOCATION to MAPSET_PATH. The name LOCATION was
 a lagacy name (see also LOCATION_NAME) reintroduced in r60216
 (not mentioned in the commit message, used locally like in the Python
 prompt).
 The LOCATION is kept for backwards compatibility and can be safely removed
 for the next major release (8.0).
Ticket URL: <https://trac.osgeo.org/grass/ticket/2681#comment:6>
