[GRASS-dev] [GRASS-SVN] r73360 - grass/branches/releasebranch_7_6/scripts/r.import
Markus Metz
markus.metz.giswork at gmail.com
Mon Sep 17 08:07:48 PDT 2018
On Mon, Sep 17, 2018 at 3:39 PM Moritz Lennert <mlennert at club.worldonline.be>
wrote:
> Markus,
> Could you explain this ? Does this mean that the memory parameter in
> r.in.gdal is now automagic ? Or why doesn't it make sens to let the user
> define in r.import the memory size ?
Markus N and me were discussing this together: r73360 removes the 2047 MB
limit in r.import, nothing else. It is now possible in r.import to define
memory larger than 2047 MB. r.in.gdal has this limit only for GDAL 1.8 and
earlier and does the checks (r.in.gdal will take care of the memory answer).
Markus M
> Moritz
> On 17/09/18 15:30, svn_grass at osgeo.org wrote:
> > Author: neteler
> > Date: 2018-09-17 06:30:25 -0700 (Mon, 17 Sep 2018)
> > New Revision: 73360
> > Modified:
> > grass/branches/releasebranch_7_6/scripts/r.import/r.import.py
> > Log:
> > r.import: remove hardcoded memory limit (r.in.gdal will take care)
> > Modified: grass/branches/releasebranch_7_6/scripts/r.import/r.import.py
> > --- grass/branches/releasebranch_7_6/scripts/r.import/r.import.py
2018-09-17 13:29:35 UTC (rev 73359)
> > +++ grass/branches/releasebranch_7_6/scripts/r.import/r.import.py
2018-09-17 13:30:25 UTC (rev 73360)
> > @@ -39,7 +39,6 @@
> > #% type: integer
> > #% required: no
> > #% multiple: no
> > -#% options: 0-2047
> > #% label: Maximum memory to be used (in MB)
> > #% description: Cache size for raster rows
> > #% answer: 300
> > grass-commit mailing list
> > grass-commit at lists.osgeo.org
> > https://lists.osgeo.org/mailman/listinfo/grass-commit
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20180917/f48cb659/attachment.html>
