[GRASS-dev] [GRASS GIS] #3650: Cartographic composer: scale and rotation options do not work for north arrow
trac at osgeo.org
Wed Sep 19 05:01:50 PDT 2018
arrow
Reporter: veroandreo | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone:
Component: Default | Version: unspecified
Keywords: | CPU: Unspecified
Platform: Unspecified |
When I try to add a North Arrow in the Cartographic composer, if I accept
all settings by default and click OK, it works, but I get a huge north
arrow.
If I then try to scale or rotate the north arrow, the apply button does
not produce any visible effect and the OK button does not close the
dialog, only the "x" in the corner does, and afterwards the grey box
representing the north arrow disappears. Then, the arrow appears in the
preview, but I do not have control over it.
I attach screenshots.
System
GRASS version: 7.7.svn
GRASS SVN revision: r73364
Build date: 2018-09-19
Build platform: x86_64-pc-linux-gnu
GDAL: 2.2.4
PROJ.4: 4.9.3
GEOS: 3.6.1
SQLite: 3.22.0
Python: 2.7.15
wxPython: 3.0.2.0
Platform: Linux-4.18.7-200.fc28.x86_64-x86_64-with-fedora-28-Twenty_Eight
Ticket URL: <https://trac.osgeo.org/grass/ticket/3650>
