[GRASS-dev] r.in.wms: decode() is not defined
Veronica Andreo veroandreo at gmail.com
Sat Sep 22 16:02:18 PDT 2018
This works! Great! Thanks, Anna :)
El mié., 19 sept. 2018 a las 19:38, Anna Petrášová (<kratochanna at gmail.com>)
escribió:
> ok, try this diff and let me know if there are more problems
> Index: scripts/r.in.wms/wms_drv.py
> --- scripts/r.in.wms/wms_drv.py (revision 73363)
> +++ scripts/r.in.wms/wms_drv.py (working copy)
> @@ -229,7 +229,7 @@
>                                          flags='wf',
>                                          epsg=self.params['srs'])
>          projection = projection.rstrip('\n')
> -        temp_map_dataset.SetProjection(projection)
> +        temp_map_dataset.SetProjection(grass.encode(projection))
>          pixel_x_length = (map_region['maxx'] - map_region['minx']) /
> int(map_region['cols'])
>          pixel_y_length = (map_region['miny'] - map_region['maxy']) /
> int(map_region['rows'])
> On Wed, Sep 19, 2018 at 11:40 AM Veronica Andreo <veroandreo at gmail.com>
> wrote:
>> Now I get a different one:
>> Traceback (most recent call last):
>>   File
>> "/home/veroandreo/software/grass7_trunk/dist.x86_64-pc-linux-gnu/gui/scripts/d.wms",
>> line 214, in <module>
>>     sys.exit(main())
>>   File
>> line 207, in main
>>     temp_map = wms.GetMap(options, flags)
>>   File
>> "/home/veroandreo/software/grass7_trunk/dist.x86_64-pc-linux-gnu/etc/r.in.wms/wms_base.py",
>> line 215, in GetMap
>>     self.temp_map = self._download()
>>   File
>> "/home/veroandreo/software/grass7_trunk/dist.x86_64-pc-linux-gnu/etc/r.in.wms/wms_drv.py",
>> line 232, in _download
>>   File "/usr/lib64/python2.7/site-packages/osgeo/gdal.py", line 1851, in
>> SetProjection
>>     return _gdal.Dataset_SetProjection(self, *args)
>> TypeError: in method 'Dataset_SetProjection', argument 2 of type 'char
>> const *'
>> GRASS_INFO_END(3660,1)
>> ERROR 4:
>> /home/veroandreo/grassdata/latlong_wgs84/pruebas/.tmp/localhost.localdomain/3210.4:
>> No such file or directory
>> ERROR 4:
>> using r73371
>> Vero
>> El mié., 19 sept. 2018 a las 15:27, Anna Petrášová (<
>> kratochanna at gmail.com>) escribió:
>>> Try r73369.
>>> On Wed, Sep 19, 2018 at 8:17 AM Veronica Andreo <veroandreo at gmail.com>
>>> wrote:
>>>> I use the module from the GUI and I get the same error as Yann in the
>>>> terminal, plus:
>>>> GRASS_INFO_END(28730,1)
>>>> ERROR 4:
>>>> /home/veroandreo/grassdata/nc_spm_08_grass7/user1/.tmp/localhost.localdomain/28556.4:
>>>> ERROR 4:
>>>> Vero
>>>> El mié., 19 sept. 2018 a las 8:50, Yann Chemin (<
>>>> dr.yann.chemin at gmail.com>) escribió:
>>>>> Hi
>>>>> maybe I am missing a library?
>>>>> /usr/local/grass-7.7.svn/scripts/r.in.wms url=url="
>>>>> https://tiles.maps.eox.at/wms?" output=sen2cloudless
>>>>> layers=s2cloudless
>>>>>   File "/usr/local/grass-7.7.svn/scripts/r.in.wms", line
>>>>> 241, in <module>
>>>>>     sys.exit(main())
>>>>> 227, in main
>>>>>     fetched_map = wms.GetMap(options, flags)
>>>>>   File "/usr/local/grass-7.7.svn/etc/r.in.wms/wms_base.py",
>>>>> line 212, in GetMap
>>>>>     self._initializeParameters(options, flags)
>>>>> line 137, in _initializeParameters
>>>>>     self.proj_srs = decode(self.proj_srs).rstrip('\n')
>>>>> NameError: global name 'decode' is not defined
>>>>> Dr. Yann Chemin
>>>>> Freelancer
>>>>> +33 7 83 85 5234
>>>>> 3 Toulmelin, 56400 Plumergat, FR
>>>>> https://www.paypal.me/yannchemin
>>>>> _______________________________________________
>>>>> grass-dev mailing list
>>>>> grass-dev at lists.osgeo.org
>>>>> https://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20180923/84dd30c7/attachment.html>
