[GRASS-dev] r.in.wms: decode() is not defined
Veronica Andreo veroandreo at gmail.com
Wed Sep 19 05:17:18 PDT 2018
I use the module from the GUI and I get the same error as Yann in the
terminal, plus:
GRASS_INFO_END(28730,1)
ERROR 4:
/home/veroandreo/grassdata/nc_spm_08_grass7/user1/.tmp/localhost.localdomain/28556.4:
No such file or directory
ERROR 4:
Vero
El mié., 19 sept. 2018 a las 8:50, Yann Chemin (<dr.yann.chemin at gmail.com>)
escribió:
> Hi
> maybe I am missing a library?
> /usr/local/grass-7.7.svn/scripts/r.in.wms url=url="
> https://tiles.maps.eox.at/wms?" output=sen2cloudless layers=s2cloudless
> Traceback (most recent call last):
>   File "/usr/local/grass-7.7.svn/scripts/r.in.wms", line
> 241, in <module>
>     sys.exit(main())
> 227, in main
>     fetched_map = wms.GetMap(options, flags)
>   File "/usr/local/grass-7.7.svn/etc/r.in.wms/wms_base.py",
> line 212, in GetMap
>     self._initializeParameters(options, flags)
> line 137, in _initializeParameters
>     self.proj_srs = decode(self.proj_srs).rstrip('\n')
> NameError: global name 'decode' is not defined
> Dr. Yann Chemin
> Freelancer
> +33 7 83 85 5234
> 3 Toulmelin, 56400 Plumergat, FR
> https://www.paypal.me/yannchemin
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20180919/471d251a/attachment.html>
