[GRASS-dev] r.in.wms: decode() is not defined
Anna Petrášová kratochanna at gmail.com
Wed Sep 19 06:27:09 PDT 2018
Try r73369.
On Wed, Sep 19, 2018 at 8:17 AM Veronica Andreo <veroandreo at gmail.com>
wrote:
> I use the module from the GUI and I get the same error as Yann in the
> terminal, plus:
> GRASS_INFO_END(28730,1)
> ERROR 4:
> /home/veroandreo/grassdata/nc_spm_08_grass7/user1/.tmp/localhost.localdomain/28556.4:
> No such file or directory
> ERROR 4:
> Vero
> El mié., 19 sept. 2018 a las 8:50, Yann Chemin (<dr.yann.chemin at gmail.com>)
> escribió:
>> Hi
>> maybe I am missing a library?
>> /usr/local/grass-7.7.svn/scripts/r.in.wms url=url="
>> https://tiles.maps.eox.at/wms?" output=sen2cloudless layers=s2cloudless
>> Traceback (most recent call last):
>>   File "/usr/local/grass-7.7.svn/scripts/r.in.wms", line
>> 241, in <module>
>>     sys.exit(main())
>> 227, in main
>>     fetched_map = wms.GetMap(options, flags)
>>   File "/usr/local/grass-7.7.svn/etc/r.in.wms/wms_base.py",
>> line 212, in GetMap
>>     self._initializeParameters(options, flags)
>> line 137, in _initializeParameters
>>     self.proj_srs = decode(self.proj_srs).rstrip('\n')
>> NameError: global name 'decode' is not defined
>> Dr. Yann Chemin
>> Freelancer
>> +33 7 83 85 5234
>> 3 Toulmelin, 56400 Plumergat, FR
>> https://www.paypal.me/yannchemin
>> grass-dev mailing list
>> grass-dev at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20180919/09e44f7f/attachment.html>
