[GRASS-dev] [GRASS GIS] #3650: Cartographic composer: scale and rotation options do not work for north arrow
trac at osgeo.org
Wed Sep 19 08:28:32 PDT 2018
arrow
Reporter: veroandreo | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone:
Component: Default | Version: unspecified
Resolution: | Keywords:
CPU: Unspecified | Platform: Unspecified
Comment (by veroandreo):
Replying to [comment:1 annakrat]:
> I can't reproduce. Maybe could you list your steps exactly how you do
it?
1. Open Cartographic composer from GUI (File--> Cartographic composer)
2. Add map frame and select elevation raster map
3. Add north arrow, select n_arrow1_fancy.eps, click OK
4. Double click over north arrow in map
5. 2 or 3 clicks over minus in Scale, Click Apply <<-- nothing
6. Click OK <<-- nothing
7. Close "North Arrow Setting" box with the x in the corner
8. North arrow becomes invisible
9. Generate preview and north arrow is there (original position and size)
Ticket URL: <https://trac.osgeo.org/grass/ticket/3650#comment:3>
