[GRASS-dev] [GRASS GIS] #3650: Cartographic composer: scale and rotation options do not work for north arrow
GRASS GIS trac at osgeo.org
Wed Sep 26 19:06:18 PDT 2018
arrow
  Reporter:  veroandreo   |      Owner:  grass-dev@…
      Type:  defect       |     Status:  new
  Priority:  normal       |  Milestone:
 Component:  Default      |    Version:  unspecified
Resolution:               |   Keywords:
       CPU:  Unspecified  |   Platform:  Unspecified
Comment (by annakrat):
 Replying to [comment:3 veroandreo]:
 > Replying to [comment:1 annakrat]:
 > > I can't reproduce. Maybe could you list your steps exactly how you do
 it?
 > 1. Open Cartographic composer from GUI (File--> Cartographic composer)
 > 2. Add map frame and select elevation raster map
 > 3. Add north arrow, select n_arrow1_fancy.eps, click OK
 > 4. Double click over north arrow in map
 > 5. 2 or 3 clicks over minus in Scale, Click Apply <<-- nothing
 > 6. Click OK <<-- nothing
 > 7. Close "North Arrow Setting" box with the x in the corner
 > 8. North arrow becomes invisible
 > 9. Generate preview and north arrow is there (original position and
 size)
 I still can't reproduce. Isn't there any error in Layer manager console?
Ticket URL: <https://trac.osgeo.org/grass/ticket/3650#comment:4>
