[GRASS-dev] r.tileset and cs2cs / cct
Stefan Blumentrath Stefan.Blumentrath at nina.no
Sat Sep 22 02:52:52 PDT 2018
Thanks for the info.
Maybe the grass-core package on Debian should suggest installing also proj-bin (maybe it does and I just overlooked)?
Ticket opened for cct-support here: https://trac.osgeo.org/grass/ticket/3653
From: Markus Metz <markus.metz.giswork at gmail.com>
Sent: fredag 21. september 2018 22:23
To: Stefan Blumentrath <Stefan.Blumentrath at nina.no>
Cc: GRASS developers list <grass-dev at lists.osgeo.org>
Subject: Re: [GRASS-dev] r.tileset and cs2cs / cct
On Fri, Sep 21, 2018 at 3:44 PM Stefan Blumentrath <Stefan.Blumentrath at nina.no<mailto:Stefan.Blumentrath at nina.no>> wrote:
> Hi,
> On my Ubuntu 16.04 box I get the following error message in GRASS 7.4.1 (package install from UbuntuGIS) with r.tileset:
> r.tileset sourceproj=+init=epsg:25833 maxrows=10000 maxcols=10000 | wc -l
> ERROR: cs2cs program not found, install PROJ.4 first:
>        http://proj.maptools.org
> ERROR: cs2cs failed
> 0
> And locate tells me that there indeed is no cs2cs on my PATH/system…
> Is that related to the move to Proj.5?
> Can GRASS even be installed without Proj?
No, it needs libproj. However, this provides only the libraries, for cs2cs / cct you also need proj-bin (on Debian-based systems).
> Is that a GRASS issue, a packaging issue or simply an installation issue?
> r.tileset should probably be updated to use cct https://proj4.org/development/migration.html (yet, I cannot find cct on my system either)…
Yes, r.tileset should use cct if available, otherwise cs2cs.
Can you please open a ticket for this issue?
Markus M
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20180922/df0d3157/attachment.html>
