[GRASS-dev] i.modis key error 'datum'
Nikos Alexandris
nik at nikosalexandris.net
Mon Sep 24 07:30:05 PDT 2018
Apparently i.modis won't run if the current projection definition does
not have the 'datum' defined. I.e., in a location like,
g.proj -p
-PROJ_INFO-------------------------------------------------
ellps : clark66
proj : ll
no_defs : defined
-PROJ_UNITS------------------------------------------------
unit : degree
units : degrees
meters : 1.0
it will fail:
i.modis.import input=MOD11A1.A2016174.h18v04.006.2016240225941.hdf
File "/home/user/.grass7/addons/scripts/i.modis.import", line 607, in <module>
sys.exit(main())
File "/home/user/.grass7/addons/scripts/i.modis.import", line 559, in main
single(options, remove, analyze, over, outfile)
File "/home/user/.grass7/addons/scripts/i.modis.import", line 360, in single
projObj = projection()
File "/home/user/.grass7/addons/etc/i.modis/rmodislib.py", line 353, in __init__
if self.proj['datum']:
KeyError: 'datum'
Should the error message be improved, i.e. provide a clue to "switch" to
another location?
Nikos
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20180924/df257884/attachment.sig>
