[GRASS-dev] i.modis key error 'datum'
Markus Neteler neteler at osgeo.org
Mon Sep 24 07:57:56 PDT 2018
On Mon, Sep 24, 2018 at 4:29 PM Nikos Alexandris
<nik at nikosalexandris.net> wrote:
> Apparently i.modis won't run if the current projection definition does
> not have the 'datum' defined. I.e., in a location like,
> g.proj -p
> -PROJ_INFO-------------------------------------------------
> ellps      : clark66
> proj       : ll
> no_defs    : defined
> -PROJ_UNITS------------------------------------------------
> unit       : degree
> units      : degrees
> meters     : 1.0
... besides error catching in i.modis, how was that location created?
Markus
