[GRASS-dev] i.modis key error 'datum'
Nikos Alexandris
nik at nikosalexandris.net
Tue Sep 25 02:41:07 PDT 2018
Nikos Alexandris:
>> Apparently i.modis won't run if the current projection definition does
>> not have the 'datum' defined. I.e., in a location like,
>> g.proj -p
>> -PROJ_INFO-------------------------------------------------
>> ellps : clark66
>> proj : ll
>> no_defs : defined
>> -PROJ_UNITS------------------------------------------------
>> unit : degree
>> units : degrees
>> meters : 1.0
Markus Neteler:
>... besides error catching in i.modis, how was that location created?
Actually, using a file from https://zenodo.org/record/1135230:
grass -c LST_2016_07_avg.tif /geo/grassdb/lst/modis_lst
and `g.proj -p` will return the above projection details.
Nikos
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20180925/bb5e7452/attachment-0001.sig>
