[GRASS-dev] seg fault with temporal modules
Veronica Andreo
veroandreo at gmail.com
Fri Sep 28 06:18:18 PDT 2018
Hi devs,
I get 'Segmentation fault (core dumped)' after running temporal commands.
Commands work, but they finish with segfault. I started observing this
yesterday evening that I recompiled trunk to get lattest temporal changes.
I was working with temporal modules the day before that with no issues.
Luca suggested off-list that my DB must be corrupted somehow because others
do not have that issue and neither myself in a different machine with
freshly compiled trunk. So, I'm lost...
To test further I did 2 things:
1). *remove my nc_basic location and download it again *in my grassdata:
GRASS 7.7.svn (nc_basic_spm_grass7):~ > t.connect -d
Default driver / database set to:
driver: sqlite
database: $GISDBASE/$LOCATION_NAME/$MAPSET/tgis/sqlite.db
GRASS 7.7.svn (nc_basic_spm_grass7):~ > t.list
WARNING: Temporal database connection defined as:
/home/veroandreo/grassdata/nc_basic_spm_grass7/PERMANENT/tgis/sqlite.db
But database file does not exist.
Creating temporal database:
2). create a *new grassdata and download a different location*
GRASS 7.7.svn (worldlocation):~ > t.connect -d
driver: sqlite
GRASS 7.7.svn (worldlocation):~ > t.list
/home/veroandreo/grassdata_test/worldlocation/PERMANENT/tgis/sqlite.db
same result... any other ideas??
Thanks much in advance!
Vero
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20180928/01c3458f/attachment-0001.html>
