[GRASS-dev] seg fault with temporal modules
Markus Neteler
neteler at osgeo.org
Fri Sep 28 07:03:08 PDT 2018
On Fri, Sep 28, 2018 at 3:18 PM Veronica Andreo <veroandreo at gmail.com> wrote:
> Hi devs,
> I get 'Segmentation fault (core dumped)' after running temporal commands. Commands work, but they finish with segfault.
We has a similar (?) problem here:
On Sat, Jul 28, 2018 at 11:40 PM Veronica Andreo wrote...
The reason was a broken external library. Maybe that problem came back
in a system update?
You may try t.info with strace like the last time.
Best
Markus
