[GRASS-dev] seg fault with temporal modules
Markus Neteler
neteler at osgeo.org
Fri Sep 28 08:37:47 PDT 2018
On Fri, Sep 28, 2018 at 4:03 PM Markus Neteler <neteler at osgeo.org> wrote:
> On Fri, Sep 28, 2018 at 3:18 PM Veronica Andreo <veroandreo at gmail.com> wrote:
> > I get 'Segmentation fault (core dumped)' after running temporal commands. Commands work, but they finish with segfault.
> We has a similar (?) problem here:
> On Sat, Jul 28, 2018 at 11:40 PM Veronica Andreo wrote...
> The reason was a broken external library. Maybe that problem came back
> in a system update?
> You may try t.info with strace like the last time.
Seems that
https://bugzilla.redhat.com/show_bug.cgi?id=1605231
may be back, i.e. bug reintroduced in openblas-0.3.3 (the update just
came in through the Fedora update channel)...
I'll check later on my system.
Best
Markus
