[GRASS-dev] seg fault with temporal modules
Markus Neteler neteler at osgeo.org
Fri Sep 28 08:46:47 PDT 2018
On Fri, Sep 28, 2018 at 5:37 PM Markus Neteler <neteler at osgeo.org> wrote:
> On Fri, Sep 28, 2018 at 4:03 PM Markus Neteler <neteler at osgeo.org> wrote:
> > On Fri, Sep 28, 2018 at 3:18 PM Veronica Andreo <veroandreo at gmail.com> wrote:
> > > I get 'Segmentation fault (core dumped)' after running temporal commands. Commands work, but they finish with segfault.
> > You may try t.info with strace like the last time.
> Seems that
> https://bugzilla.redhat.com/show_bug.cgi?id=1605231
> may be back, i.e. bug reintroduced in  openblas-0.3.3 (the update just
> came in through the Fedora update channel)...
Reported upstream as
https://bugzilla.redhat.com/show_bug.cgi?id=1634060
Markus
