[GRASS-dev] seg fault with temporal modules
Markus Neteler
neteler at osgeo.org
Sun Sep 30 09:04:45 PDT 2018
Markus Neteler <neteler at osgeo.org> schrieb am Fr., 28. Sep. 2018, 17:46:
> On Fri, Sep 28, 2018 at 5:37 PM Markus Neteler <neteler at osgeo.org> wrote:
> > On Fri, Sep 28, 2018 at 4:03 PM Markus Neteler <neteler at osgeo.org>
> wrote:
> > > On Fri, Sep 28, 2018 at 3:18 PM Veronica Andreo <veroandreo at gmail.com>
> wrote:
> > > > I get 'Segmentation fault (core dumped)' after running temporal
> commands. Commands work, but they finish with segfault.
> > > You may try t.info with strace like the last time.
> > Seems that
> > https://bugzilla.redhat.com/show_bug.cgi?id=1605231
> > may be back, i.e. bug reintroduced in openblas-0.3.3 (the update just
> > came in through the Fedora update channel)...
> Reported upstream as
> https://bugzilla.redhat.com/show_bug.cgi?id=1634060
Fixed upstream:
<bugzilla at redhat.com> schrieb am So., 30. Sep. 2018, 15:44:
--- Comment #2 from Fedora Update System <updates at fedoraproject.org> ---
openblas-0.3.3-2.fc28 has been submitted as an update to Fedora 28.
https://bodhi.fedoraproject.org/updates/FEDORA-2018-dcb9bcdb5c
It may take a day to propagate through the update channel.
Other distros will follow or still have an older openblas package version...
Cheers,
Markus
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20180930/63843e4e/attachment.html>
