[GRASS-dev] seg fault with temporal modules
Veronica Andreo
veroandreo at gmail.com
Sun Sep 30 12:08:17 PDT 2018
Hi Markus,
Thanks much for reporting the issue and then reporting back here. I had
completely forgotten that we had the same issue shortly ago... eheh
Cheers,
Vero
El dom., 30 sep. 2018 13:04, Markus Neteler <neteler at osgeo.org> escribió:
> Markus Neteler <neteler at osgeo.org> schrieb am Fr., 28. Sep. 2018, 17:46:
>> On Fri, Sep 28, 2018 at 5:37 PM Markus Neteler <neteler at osgeo.org> wrote:
>> > On Fri, Sep 28, 2018 at 4:03 PM Markus Neteler <neteler at osgeo.org>
>> wrote:
>> > > On Fri, Sep 28, 2018 at 3:18 PM Veronica Andreo <veroandreo at gmail.com>
>> wrote:
>> > > > I get 'Segmentation fault (core dumped)' after running temporal
>> commands. Commands work, but they finish with segfault.
>> > > You may try t.info with strace like the last time.
>> > Seems that
>> > https://bugzilla.redhat.com/show_bug.cgi?id=1605231
>> > may be back, i.e. bug reintroduced in openblas-0.3.3 (the update just
>> > came in through the Fedora update channel)...
>> Reported upstream as
>> https://bugzilla.redhat.com/show_bug.cgi?id=1634060
> Fixed upstream:
> <bugzilla at redhat.com> schrieb am So., 30. Sep. 2018, 15:44:
> --- Comment #2 from Fedora Update System <updates at fedoraproject.org> ---
> openblas-0.3.3-2.fc28 has been submitted as an update to Fedora 28.
> https://bodhi.fedoraproject.org/updates/FEDORA-2018-dcb9bcdb5c
> It may take a day to propagate through the update channel.
> Other distros will follow or still have an older openblas package
> version...
> Cheers,
> Markus
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20180930/20198fbe/attachment.html>
