[GRASS-dev] [release] planning GRASS 7.4.2
Anna Petrášová kratochanna at gmail.com
Fri Sep 28 13:38:26 PDT 2018
Markus, I will try to solve the remaining issues over the weekend, but new
might pop up, because Michael is working with wxPython 4, which hasn't been
tested widely. These are usually easy to fix and test. If you want to
create RC now, go ahead and do it i would say.
Anna
On Fri, Sep 28, 2018 at 4:29 PM Michael Barton <Michael.Barton at asu.edu>
wrote:
> The map frame creation is now fixed  (see
> https://trac.osgeo.org/grass/ticket/3621) and maps can be added to the
> composer. This allowed me to test the rest of the cartographic composer. It
> is not possible to select a symbol for points (also broken for vector
> display) or create a scale bar. I've reported both of these on the ticket.
> We're getting closer to functionality. This will have down the line
> benefits for all.
> You can get a map out of GRASS now, but the cartographic composer is not
> useable for most cartography yet. This has been reclassified from blocker
> to critical.
> Michael
> ______________________________
> C. Michael Barton
> Director, Center for Social Dynamics & Complexity
> Professor of Anthropology, School of Human Evolution & Social Change
> Head, Graduate Faculty in Complex Adaptive Systems Science
> Arizona State University
> Tempe, AZ  85287-2402
> USA
> voice:    480-965-6262 (SHESC), 480-965-8130/727-9746 (CSDC)
> fax:          480-965-7671(SHESC), 480-727-0709 (CSDC)
> www:      http://csdc.asu.edu, http://shesc.asu.edu
>                                 http://www.public.asu.edu/~cmbarton
> On 9/28/18, 1:20 PM, "Markus Neteler" <neteler at osgeo.org> wrote:
>     On Tue, Sep 25, 2018 at 9:48 PM Michael Barton <Michael.Barton at asu.edu>
> wrote:
>     > That would be great. It seems to be that when the mouse is released
> after making the rubber-band box, it is not triggering the event to make
> the bounding box for the cartography. My proposal goes in tomorrow, so I
> can test.
>     Has this been solved? I would like to prepare RC1.
>     thanks
>     Markus
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20180928/00a5d41b/attachment.html>
