[GRASS-dev] [GRASS-SVN] r74358 - grass/trunk/lib/python/temporal
Anna Petrášová
kratochanna at gmail.com
Tue Apr 9 19:37:24 PDT 2019
Documented here:
https://trac.osgeo.org/grass/wiki/Python3Support#HowtowritePython3compatiblecode
On Tue, Apr 9, 2019 at 10:34 PM Anna Petrášová <kratochanna at gmail.com>
wrote:
> Hi,
> it should really be >= 3 to avoid failing for future Python versions:
> http://astrofrog.github.io/blog/2016/01/12/stop-writing-python-4-incompatible-code/
> On Tue, Apr 9, 2019 at 5:07 AM <svn_grass at osgeo.org> wrote:
>> Author: sbl
>> Date: 2019-04-09 02:07:30 -0700 (Tue, 09 Apr 2019)
>> New Revision: 74358
>> Modified:
>> grass/trunk/lib/python/temporal/datetime_math.py
>> grass/trunk/lib/python/temporal/temporal_algebra.py
>> Log:
>> fix python version check
>> Modified: grass/trunk/lib/python/temporal/datetime_math.py
>> --- grass/trunk/lib/python/temporal/datetime_math.py 2019-04-08
>> 19:50:21 UTC (rev 74357)
>> +++ grass/trunk/lib/python/temporal/datetime_math.py 2019-04-09
>> 09:07:30 UTC (rev 74358)
>> @@ -19,7 +19,7 @@
>> except:
>> has_dateutil = False
>> -if sys.version_info[0]:
>> +if sys.version_info[0] == 3:
>> unicode = str
>> DAY_IN_SECONDS = 86400
>> Modified: grass/trunk/lib/python/temporal/temporal_algebra.py
>> --- grass/trunk/lib/python/temporal/temporal_algebra.py 2019-04-08
>> +++ grass/trunk/lib/python/temporal/temporal_algebra.py 2019-04-09
>> @@ -470,7 +470,7 @@
>> from .datetime_math import create_time_suffix
>> from .datetime_math import create_numeric_suffix
>> unicode = str
>> grass-commit mailing list
>> grass-commit at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/grass-commit
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20190409/7a50ef79/attachment.html>
