[GRASS-dev] [GRASS-SVN] r74358 - grass/trunk/lib/python/temporal
Stefan Blumentrath Stefan.Blumentrath at nina.no
Wed Apr 10 00:56:04 PDT 2019
Hi Anna and others,
Sorry for the mistake and thanks for the heads up! Good to see that experienced devs are on the watch!
Fixed in r74361
For the record, there is still:
lib/python/imaging/images2swf.py:87:PY3 = sys.version_info[0] == 3
which I did not touch.
Cheers
Stefan
From: grass-dev <grass-dev-bounces at lists.osgeo.org> On Behalf Of Anna Petrášová
Sent: onsdag 10. april 2019 04:37
To: GRASS-dev <grass-dev at lists.osgeo.org>
Cc: grass-commit at lists.osgeo.org
Subject: Re: [GRASS-dev] [GRASS-SVN] r74358 - grass/trunk/lib/python/temporal
Documented here:
https://trac.osgeo.org/grass/wiki/Python3Support#HowtowritePython3compatiblecode
On Tue, Apr 9, 2019 at 10:34 PM Anna Petrášová <kratochanna at gmail.com<mailto:kratochanna at gmail.com>> wrote:
it should really be >= 3 to avoid failing for future Python versions:
http://astrofrog.github.io/blog/2016/01/12/stop-writing-python-4-incompatible-code/
On Tue, Apr 9, 2019 at 5:07 AM <svn_grass at osgeo.org<mailto:svn_grass at osgeo.org>> wrote:
Author: sbl
Date: 2019-04-09 02:07:30 -0700 (Tue, 09 Apr 2019)
New Revision: 74358
   grass/trunk/lib/python/temporal/datetime_math.py
   grass/trunk/lib/python/temporal/temporal_algebra.py
fix python version check
Modified: grass/trunk/lib/python/temporal/datetime_math.py
--- grass/trunk/lib/python/temporal/datetime_math.py    2019-04-08 19:50:21 UTC (rev 74357)
+++ grass/trunk/lib/python/temporal/datetime_math.py    2019-04-09 09:07:30 UTC (rev 74358)
@@ -19,7 +19,7 @@
 except:
     has_dateutil = False
-if sys.version_info[0]:
+if sys.version_info[0] == 3:
     unicode = str
 DAY_IN_SECONDS = 86400
Modified: grass/trunk/lib/python/temporal/temporal_algebra.py
--- grass/trunk/lib/python/temporal/temporal_algebra.py 2019-04-08 19:50:21 UTC (rev 74357)
+++ grass/trunk/lib/python/temporal/temporal_algebra.py 2019-04-09 09:07:30 UTC (rev 74358)
@@ -470,7 +470,7 @@
 from .datetime_math import create_time_suffix
 from .datetime_math import create_numeric_suffix
     unicode = str
grass-commit mailing list
grass-commit at lists.osgeo.org<mailto:grass-commit at lists.osgeo.org>
https://lists.osgeo.org/mailman/listinfo/grass-commit
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20190410/c9e12058/attachment-0001.html>
