[GRASS-dev] Fwd: [gdal-dev] shapelib 1.5.0 release
Markus Neteler neteler at osgeo.org
Sat Apr 13 10:23:57 PDT 2019
Hi devs,
we still have an older copy of shapelib in
lib/external/shapelib/
Is that still needed/wanted for the upcoming 7.8.0 release?
If yes, to be updated?
Markus
---------- Forwarded message ---------
Date: Thu, Feb 28, 2019 at 5:14 PM
Subject: [gdal-dev] shapelib 1.5.0 release
To: <shapelib at lists.osgeo.org>
Cc: <gdal-dev at lists.osgeo.org>
(CC'ing gdal-dev as well, since shapelib at lists.osgeo.org has likely lower
audience)
I've released shapelib 1.5.0
The main change is the removal of the 'shpproj' contrib utility and thus PROJ
dependency.
The tarballs are available at:
http://download.osgeo.org/shapelib/shapelib-1.5.0.tar.gz
http://download.osgeo.org/shapelib/shapelib-1.5.0.zip
The log of changes since 1.4.1 is:
2019-02-28  Even Rouault  <even.rouault at spatialys.com>
        * shpopen.c: resync with GDAL internal shapelib to avoid being dependent
        on correctness of file size field in .shp. Fixes
        https://lists.osgeo.org/pipermail/gdal-dev/2018-October/049218.html
        * contrib/shpgeo.h/.c: Remove PROJ.4 dependency and functionality,
         causing removal of SHPProject(), SHPSetProjection() and
SHPFreeProjection()
        * contrib/shpproj.c: removed
2018-08-16  Even Rouault  <even.rouault at spatialys.com>
        * shpopen.c, dbfopen.c, shptree.c, sbnsearch.c: resyc with GDAL
        internal shapelib. Mostly to allow building those files as C++
        without warning. Also add FTDate entry in DBFFieldType
        (see https://github.com/OSGeo/gdal/pull/308). And some other
        code cleanups
        * dbfopen.c: fix a bug where the end of file character was
        written on top of the first character of the first field name
        when deleting a field on a .dbf without records.
        Fixes https://github.com/OSGeo/gdal/issues/863
2018-06-15  Even Rouault  <even.rouault at spatialys.com>
        * safileio.c: remove duplicate test. Patch by Jaroslav Fojtik.
        Fixes http://bugzilla.maptools.org/show_bug.cgi?id=2744
Even
http://www.spatialys.com
gdal-dev mailing list
https://lists.osgeo.org/mailman/listinfo/gdal-dev
