[GRASS-dev] Fwd: [gdal-dev] shapelib 1.5.0 release
Markus Metz
markus.metz.giswork at gmail.com
Sat Apr 13 12:41:09 PDT 2019
On Sat, Apr 13, 2019 at 7:24 PM Markus Neteler <neteler at osgeo.org> wrote:
> Hi devs,
> we still have an older copy of shapelib in
> lib/external/shapelib/
> Is that still needed/wanted for the upcoming 7.8.0 release?
> If yes, to be updated?
GRASS is only using the dbf driver of shapelib. Updating is not not needed
but would be nice to keep in sync with upstream. I can do it in the next
few days.
Markus M
> Markus
> ---------- Forwarded message ---------
> From: Even Rouault <even.rouault at spatialys.com>
> Date: Thu, Feb 28, 2019 at 5:14 PM
> Subject: [gdal-dev] shapelib 1.5.0 release
> To: <shapelib at lists.osgeo.org>
> Cc: <gdal-dev at lists.osgeo.org>
> Hi,
> (CC'ing gdal-dev as well, since shapelib at lists.osgeo.org has likely lower
> audience)
> I've released shapelib 1.5.0
> The main change is the removal of the 'shpproj' contrib utility and thus
> dependency.
> The tarballs are available at:
> http://download.osgeo.org/shapelib/shapelib-1.5.0.tar.gz
> http://download.osgeo.org/shapelib/shapelib-1.5.0.zip
> The log of changes since 1.4.1 is:
> 2019-02-28 Even Rouault <even.rouault at spatialys.com>
> * shpopen.c: resync with GDAL internal shapelib to avoid being
dependent
> on correctness of file size field in .shp. Fixes
https://lists.osgeo.org/pipermail/gdal-dev/2018-October/049218.html
> * contrib/shpgeo.h/.c: Remove PROJ.4 dependency and functionality,
> causing removal of SHPProject(), SHPSetProjection() and
> SHPFreeProjection()
> * contrib/shpproj.c: removed
> 2018-08-16 Even Rouault <even.rouault at spatialys.com>
> * shpopen.c, dbfopen.c, shptree.c, sbnsearch.c: resyc with GDAL
> internal shapelib. Mostly to allow building those files as C++
> without warning. Also add FTDate entry in DBFFieldType
> (see https://github.com/OSGeo/gdal/pull/308). And some other
> code cleanups
> * dbfopen.c: fix a bug where the end of file character was
> written on top of the first character of the first field name
> when deleting a field on a .dbf without records.
> Fixes https://github.com/OSGeo/gdal/issues/863
> 2018-06-15 Even Rouault <even.rouault at spatialys.com>
> * safileio.c: remove duplicate test. Patch by Jaroslav Fojtik.
> Fixes http://bugzilla.maptools.org/show_bug.cgi?id=2744
> Even
> Spatialys - Geospatial professional services
> http://www.spatialys.com
> gdal-dev mailing list
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20190413/1427c874/attachment.html>
