[GRASS-dev] [GRASS GIS] #3815: compression: libzstd should be a default config and a requirement if ZSTD is default compression method
trac at osgeo.org
Wed Apr 17 10:04:27 PDT 2019
Reporter: mlennert | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.8.0
Component: Raster | Version: svn-trunk
Keywords: compression zstd zlib | CPU: Unspecified
Platform: Unspecified |
I just came upon the problem that in my grass installation ZSTD is
configured and I thus worked with raster data which was automatically
compressed using ZSTD, but when I transferred the data to our HPC system,
I realized that grass there is not configure with ZSTD and the latter is
currently not available on the system.
As the r.compress man page says, ZSTD is the default compressor if
available. However, when I check in current trunk's configure, it says:
--with-zstd support Zstandard functionality (default: no)"
Does that mean that even if libzstd is available on a system, GRASS is not
compiled with support for it, unless --with-zstd is set ?
I find this situation a bit uncomfortable as it can lead to situations
where the user creates data without actively thinking about the
compression method and this data is the unusable elsewhere.
I would plead, thus, for libzstd to become a compulsory requirement for
GRASS GIS, and for the configure script to default to --with-zstd=yes.
Or the default compression method should be put back to ZLIB.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3815>
