[GRASS-dev] [GRASS GIS] #3815: compression: libzstd should be a default config and a requirement if ZSTD is default compression method
trac at osgeo.org
Wed Apr 17 13:25:40 PDT 2019
Reporter: mlennert | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.8.0
Component: Raster | Version: svn-trunk
Resolution: | Keywords: compression zstd zlib
CPU: Unspecified | Platform: Unspecified
Comment (by mmetz):
Replying to [ticket:3815 mlennert]:
> I just came upon the problem that in my grass installation ZSTD is
configured and I thus worked with raster data which was automatically
compressed using ZSTD, but when I transferred the data to our HPC system,
I realized that grass there is not configure with ZSTD and the latter is
currently not available on the system.
> As the r.compress man page says, ZSTD is the default compressor if
available. However, when I check in current trunk's configure, it says:
> --with-zstd support Zstandard functionality (default: no)"
> Does that mean that even if libzstd is available on a system, GRASS is
not compiled with support for it, unless --with-zstd is set ?
yes
> I find this situation a bit uncomfortable as it can lead to situations
where the user creates data without actively thinking about the
compression method and this data is the unusable elsewhere.
> I would plead, thus, for libzstd to become a compulsory requirement for
GRASS GIS, and for the configure script to default to --with-zstd=yes.
Done in trunk r74391. The default is now `--with-zstd=yes`, you can
disable ZSTD support with `--with-zstd=no`. To be backported I guess.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3815#comment:1>
