[GRASS-dev] [GRASS GIS] #3815: compression: libzstd should be a default config and a requirement if ZSTD is default compression method
GRASS GIS trac at osgeo.org
Fri Apr 19 13:53:43 PDT 2019
  Reporter:  mlennert     |      Owner:  grass-dev@…
      Type:  defect       |     Status:  new
  Priority:  normal       |  Milestone:  7.6.2
 Component:  Raster       |    Version:  svn-trunk
Resolution:               |   Keywords:  compression zstd zlib
       CPU:  Unspecified  |   Platform:  Unspecified
Comment (by mmetz):
 Replying to [comment:5 neteler]:
 > Replying to [comment:3 mmetz]:
 > > Replying to [comment:2 mlennert]:
 > > > +1 for backporting.
 > > Done in relbr76 r74398
 > Just FYI:
 > This broke the manual-building cronjobs on the grass.osgeo.org server
 but I fixed it by now actively disabling zstd in the configure step
 (Debian Jessie doesn't have zstd yet and #3486 = compile in a docker
 container is still open).
 A good reason to not make zstd a compulsory requirement. Debian Jessie has
 long-term support until 30 June 2020, and GRASS 7.x should IMHO run on
 this system (with appropriate configure options).
Ticket URL: <https://trac.osgeo.org/grass/ticket/3815#comment:6>
