[GRASS-dev] [GRASS GIS] #3815: compression: libzstd should be a default config and a requirement if ZSTD is default compression method
trac at osgeo.org
Thu Apr 25 12:22:02 PDT 2019
Reporter: mlennert | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.6.2
Component: Raster | Version: svn-trunk
Resolution: | Keywords: compression zstd zlib
CPU: Unspecified | Platform: Unspecified
Comment (by mmetz):
In [changeset:"74426" 74426]:
#!CommitTicketReference repository="" revision="74426"
libgis: make ZLIB the default compressor even if ZSTD is available, see
#3815
Ticket URL: <https://trac.osgeo.org/grass/ticket/3815#comment:10>
