[GRASS-dev] [GRASS GIS] #3815: compression: libzstd should be a default config and a requirement if ZSTD is default compression method
trac at osgeo.org
Thu Apr 25 12:28:10 PDT 2019
Reporter: mlennert | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.6.2
Component: Raster | Version: svn-trunk
Resolution: | Keywords: compression zstd zlib
CPU: Unspecified | Platform: Unspecified
Comment (by mmetz):
Replying to [comment:10 mmetz]:
> In [changeset:"74426" 74426]:
> #!CommitTicketReference repository="" revision="74426"
> libgis: make ZLIB the default compressor even if ZSTD is available, see
#3815
This change means that newly created raster maps are by default compressed
with ZLIB, unless the environment variable GRASS_COMPRESSOR is set.
Previously created raster maps compressed with ZSTD are readable as long
as GRASS 7.6 is compiled with ZSTD.
Trunk still uses ZSTD as default if available.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3815#comment:11>
