[GRASS-dev] pygrass.gis.Region API explanations
Panagiotis Mavrogiorgos
pmav99 at gmail.com
Sat Apr 27 08:30:03 PDT 2019
Hello all,
I am trying to use the pygrass API to create a contextmanager that set's a
temporary Region, but I am not sure which method I should be using. The
following methods seem to be relevant:
Region.set_current()
Region.set_raster_region()
Region.write()
Could someone further clarify when each one should be used?
all the best,
Panos
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20190427/c6c7bd34/attachment.html>
