[GRASS-dev] g.extension: still fetching from SVN?
Markus Neteler
neteler at osgeo.org
Thu Aug 1 10:25:50 PDT 2019
Hi Andy,
On Thu, Aug 1, 2019 at 6:43 PM Andy Wickert <andrewwickert at gmail.com> wrote:
> Hi all,
> I have just updated to GRASS 7.6.1 on the Ubuntu grass-devel ppa. It now find the set of relatively new add-ons that I have built (r.flowfill; r.richdem.*) with the "-l" flag, but when I try to install them, I receive, for example, "ERROR: Extension <r.flowfill> not found". Is this simply that I must compile the most recent version from source, or is there some other problem?
I have merged it only now (before it was an open pull request).
Now the binaries need to be rebuild - or you compile yourself - or you
simply update the g.extension.py which does not need to be compiled
but just put into the right place.
Best
Markus
