[GRASS-dev] Contributing to addons on GitHub
Brendan brendan.harmon at gmail.com
Mon Dec 30 15:03:22 PST 2019
Thanks. Got it.
Documentation with old instructions includes:
How to Contribute
https://trac.osgeo.org/grass/wiki/HowToContribute#SettingupthenewSVNwriteaccessafteracceptance
Submitting
https://trac.osgeo.org/grass/wiki/Submitting#GRASSGISAddons
https://trac.osgeo.org/grass/wiki/Submitting#SubmittingcodetoSVN
How to SVN
https://trac.osgeo.org/grass/wiki/HowToSVN
The GitHub GRASS Addons repo contains SVN_HOWTO.txt
<https://github.com/OSGeo/grass-addons/blob/master/SVN_HOWTO.txt>
rather than a git HOWTO like https://trac.osgeo.org/grass/wiki/HowToGit
I think a link in the README to https://trac.osgeo.org/grass/wiki/HowToGit
would help.
Submitting Python Code
https://trac.osgeo.org/grass/wiki/Submitting/Python
mentions svn diff which could be updated to git diff
I believe there was a discussion on the grass-dev list about using Python
Black for style.
Was there a decision? That could be added to this wiki page.
-Brendan
On Mon, Dec 30, 2019 at 3:04 PM Markus Neteler <neteler at osgeo.org> wrote:
> Hi,
> Brendan <brendan.harmon at gmail.com> schrieb am Mo., 30. Dez. 2019, 21:27:
>> With the migration to GitHub, what exactly is the process for making
>> contributions to the addons repository?
> Please fork, edit/add and make pull requests.
> Some of the documentation still covers SVN rather than git.
> Ok that should be updated accordingly.
> Which docs do you refer to?
> Can I directly pull, commit, and push from master or should I make a
>> branch and then submit a pull request?
> A PR is the preferred way.
> If it is your own code you can also merge right away. If it is other
> author's code, some feedback might be fair to be obtained (via PR) but it
> also depends a bit on the case.
> HTH, my 0.02 cents,
> Markus
> Thanks, Brendan
>> grass-dev mailing list
>> grass-dev at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20191230/17d6e564/attachment.html>
