[GRASS-dev] [GRASS GIS] #3750: Grass 7.7.svn (r74061): GUI location widget cannot read .prj file for new location
trac at osgeo.org
Sat Feb 9 07:42:02 PST 2019
location
Reporter: rshepard | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone:
Component: wxGUI | Version: svn-trunk
Resolution: | Keywords: locaton wizard, .prj file
CPU: x86-32 | Platform: Linux
Comment (by hellik):
Replying to [ticket:3750 rshepard]:
> Trying to create a new location using a shapefile .prj. GRASS tells me
it annot read the file using gdal.
for me it works with the GUI location wizard; see attached screenshot to
choose the option ''read projection from a .prj file''.
> Markus N. confirms this and recommends using the .shp file instead.
that's the option read projection from a georeferenced file.
> Setting the location's projection on the command line works, but not
from the GUI. The 2019-02-09 thread has more details.
isn't it the other way around?
CLI with .prj file doesn't work, but GUI with .prj file works.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3750#comment:1>
