[GRASS-dev] [GRASS GIS] #3750: Grass 7.7.svn (r74061): GUI location widget cannot read .prj file for new location
trac at osgeo.org
Sat Feb 9 09:00:22 PST 2019
location
Reporter: rshepard | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone:
Component: wxGUI | Version: svn-trunk
Resolution: | Keywords: locaton wizard, .prj file
CPU: x86-32 | Platform: Linux
Comment (by neteler):
# write out user's WKT string as .prj file
echo
'PROJCS["NAD_1983_UTM_Zone_11N",GEOGCS["GCS_North_American_1983",DATUM["D_North_American_1983",SPHEROID["GRS_1980",6378137,298.257222101]],PRIMEM["Greenwich",0],UNIT["Degree",0.017453292519943295]],PROJECTION["Transverse_Mercator"],PARAMETER["latitude_of_origin",0],PARAMETER["central_meridian",-117],PARAMETER["scale_factor",0.9996],PARAMETER["false_easting",500000],PARAMETER["false_northing",0],UNIT["Meter",1]]'
> bla.prj
# attempt to generate a new location from it:
grass77 -c bla.prj ~/grassdata/mylocation
Starting GRASS GIS...
Creating new GRASS GIS location <mylocation>...
ERROR: ERROR 4: `bla.prj' not recognized as a supported file format.
ERROR: Unable to read georeferenced file <bla.prj> using GDAL library
I checked further and found a difference between g.proj and
gdalsrsinfo opening files:
general/g.proj/input.c, line 271 :
(inofficially: https://github.com/GRASS-GIS/grass-
ci/blob/master/general/g.proj/input.c#L271)
if ((gdal_ds = GDALOpen(geofile, GA_ReadOnly))) {
apps/gdalsrsinfo.cpp, line 306
https://github.com/OSGeo/gdal/blob/master/gdal/apps/gdalsrsinfo.cpp#L306
poGDALDS = static_cast<GDALDataset *>(GDALOpenEx( pszInput, 0,
nullptr, nullptr, nullptr ));
It seems that GDALOpenEx() is more flexible concerning the input (it
exists since GDAL 2.0):
https://www.gdal.org/classGDALDataset.html#a9cb8585d0b3c16726b08e25bcc94274a
Perhaps g.proj could be updated accordingly?
Ticket URL: <https://trac.osgeo.org/grass/ticket/3750#comment:2>
