[GRASS-dev] error when compiling grass with pdal
Paulo van Breugel
p.vanbreugel at gmail.com
Wed Jan 2 06:48:30 PST 2019
Hi Markus
Thanks for your reply. It was the first time I compiled. Running sudo
ldconfig did not help. When running export
LD_LIBRARY_PATH="/usr/local/lib:$LD_LIBRARY_PATH" first, grass compiles
without errors with pdal (mentioned in
https://trac.osgeo.org/grass/ticket/2732). (so I guess I am doing
something wrong on the ldconfig part).
When trying to run v.in.pdal, however, I get the following:
v.in.pdal
v.in.pdal: error while loading shared libraries: libpdal_base.so.5: cannot open shared object file: No such file or directory
After creating symlinks libpdal_base.so.5 pointing to libpdal_base.so.7
and libpdal_utils.so.5 pointing to libpdal_utils.so.7, I can open the
v.in.pdal window, but when trying to run (e.g., importing the demo data
from
https://grasswiki.osgeo.org/wiki/Processing_lidar_and_UAV_point_clouds_in_GRASS_GIS_(workshop_at_FOSS4G_Boston_2017)#Addons)
I am getting a segmentation fault:
v.in.pdal input=/home/paulo/Desktop/nc_tile_0793_016_spm.las output=test2
Running PDAL algorithms...
Segmentation fault (core dumped)
Any ideas how to solve this?
On 1/2/19 3:26 PM, Markus Neteler wrote:
> Hi,
> Am Mi., 2. Jan. 2019, 14:58 hat Paulo van Breugel
> <p.vanbreugel at gmail.com <mailto:p.vanbreugel at gmail.com>> geschrieben:
> Hi devs,
> I am trying to compile grass with pdal. My system is Ubuntu 18.04,
> grass 7.7.svn (r73901), pdal 1.8.0 (git-version: dfface).
> When trying to compile with
> --with-pdal=/usr/local/bin/pdal-config
> I get the following error message:
> Errors in:
> /home/paulo/Software/Linux/grass7/trunk/vector/v.in.pdal
> When running make in the v.in.pdal folder, I get:
> make
> if [ "/home/paulo/Software/Linux/grass7/trunk/dist.x86_64-pc-linux-gnu/bin/v.in.pdal" != "" ] ; then GISRC=/home/paulo/Software/Linux/grass7/trunk/dist.x86_64-pc-linux-gnu/demolocation/.grassrc77 GISBASE=/home/paulo/Software/Linux/grass7/trunk/dist.x86_64-pc-linux-gnu PATH="/home/paulo/Software/Linux/grass7/trunk/dist.x86_64-pc-linux-gnu/bin:/home/paulo/Software/Linux/grass7/trunk/dist.x86_64-pc-linux-gnu/bin:/home/paulo/Software/Linux/grass7/trunk/dist.x86_64-pc-linux-gnu/scripts:$PATH" PYTHONPATH="/home/paulo/Software/Linux/grass7/trunk/dist.x86_64-pc-linux-gnu/etc/python:/home/paulo/Software/Linux/grass7/trunk/dist.x86_64-pc-linux-gnu/gui/wxpython:$PYTHONPATH" LD_LIBRARY_PATH="/home/paulo/Software/Linux/grass7/trunk/dist.x86_64-pc-linux-gnu/bin:/home/paulo/Software/Linux/grass7/trunk/dist.x86_64-pc-linux-gnu/bin:/home/paulo/Software/Linux/grass7/trunk/dist.x86_64-pc-linux-gnu/scripts:/home/paulo/Software/Linux/grass7/trunk/dist.x86_64-pc-linux-gnu/lib:/home/paulo/Software/Linux/grass7/trunk/dist.x86_64-pc-linux-gnu/lib:" LC_ALL=C LANG=C LANGUAGE=C /home/paulo/Software/Linux/grass7/trunk/dist.x86_64-pc-linux-gnu/bin/v.in.pdal --html-description < /dev/null | grep -v '</body>\|</html>' > v.in.pdal.tmp.html ; fi
> /home/paulo/Software/Linux/grass7/trunk/dist.x86_64-pc-linux-gnu/bin/v.in.pdal: error while loading shared libraries: libpdal_base.so.7: cannot open shared object file: No such file or directory
> ../../include/Make/Html.make:14: recipe for target 'v.in.pdal.tmp.html' failed
> make: *** [v.in.pdal.tmp.html] Error 1
> rm v.in.pdal.tmp.html
> Any idea what I am doing wrong?
> In case you updated PDAL, did you run
> sudo ldconfig
> Markus
> Cheers,
> Paulo
> grass-dev mailing list
> grass-dev at lists.osgeo.org <mailto:grass-dev at lists.osgeo.org>
> https://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20190102/66d0c713/attachment-0001.html>
