[GRASS-dev] On `svn propset`
Markus Neteler
neteler at osgeo.org
Sun Jan 13 05:53:13 PST 2019
Hi Nikos,
On Sun, Jan 13, 2019 at 1:10 PM Nikos Alexandris
<nik at nikosalexandris.net> wrote:
> Dears,
> I copied over a "new" version of a python script (local) into the
> 'grass-addons' directory (which is the SVN repository). The `file`
> command when run on the file in question, returns:
> file r.estimap.recreation.py
> r.estimap.recreation.py: Python script, UTF-8 Unicode text executable, with very long lines
> I think I've correctly re-set the properties via
> svn propset svn:eol-style "native" r.estimap.recreation.py
> property 'svn:eol-style' set on 'r.estimap.recreation.py'
> and
> svn propset svn:mime-type text/x-python r.estimap.recreation.py
> property 'svn:mime-type' set on 'r.estimap.recreation.py'
Do you run that manually or use the helper script
grass-addons/tools/module_svn_propset.sh *
> My question is: how do I tell the difference after having applied these
> commands? `svn diff` or `svn status` don't show up anything?
It should!
Markus
